MAP pipe question
does it matter which side of the intercooler it is on?
Will be doing bam inlet conversion for FMIC so don't know if it has to be in between turbo to intercooler or turbo to throttle body or if it matters....
I'm pretty sure it won't make any difference at all. In theory it'll be more accurate the closer it is to the throttle body.
Just for example you had the sensor before the cooler reading 20psi, but the cooler had a small hole in it, the inlet manifold could only be getting 15psi
Ok well it's the last thing before the throttle body on standard setup so I'll do that then just means I'll have to extend the wires
