Octavia AGR Engine will not start 17656 - Please Help!
Driving the Octavia AGR 1.9TDI and all has been good and suddenly draws to a stop like it's run out of fuel! :heartbreak: :heartbreak: :heartbreak:
Get it home and start playing under bonnet and its starts?
Drive it a couple of miles and it stops again!
Tow it home & changed fuel filter, put diesel in filter down fuel pipe and can't get it to fire?
I have checked Cam belt & Timing etc and all is good.
Put the Snap on Diagnositic on it and it give's code  No. 17656
What do you think people because it's got me stumped.....
I tried to remove the N108 from the pump to clean it and it's a little ****er :swear:  to get out so thought I better check on here before pulling it all apart to find that I'm pulling the wrong things off.
Thanks for you help! :thumbup:
Thanks for reply and have checked this but hoped someone may have a more definitive answer.
I have now checked the N108 for resistance and it is 15 Ohms so all good?
Has anyone else had this problem?
Please help as I need to get it running again.
Edited by ? ? Miss Fabia ? ?
