No communication with ABS controller
Has anyone had a similar problem to this. When running a scan i get these results. all linked to ABS except Boost controller. Any help would be greatly appreciated.
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 76
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 HF    HW: 028 101 229 2
   Component: R4 2,0L EDC G000SG  7000
   Revision: 12345678    Serial number: SKZ7Z0E2993821
   Coding: 0000072
   Shop #: WSC 73430 790 00000
   VCID: 6ED9D061798C249
2 Faults Found:
18057 - Powertrain Data Bus
            P1649 - 000 - Missing Message from ABS Controller
             Freeze Frame:
                    RPM: 798 /min
                    Torque: 20.0 Nm
                    Speed: 4.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00001100
                    Torque: 166.0 Nm
                    Bin. Bits: 00000000
16621 - Manifold Pressure / Boost Sensor (G31)
            P0237 - 000 - Signal too Low
             Freeze Frame:
                    RPM: 798 /min
                    Torque: 16.0 Nm
                    Speed: 4.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00001100
                    Absolute Pres.: 1009.8 mbar
                    Absolute Pres.: 2182.8 mbar
Readiness: 1 2 0 0 1
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 J
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3D7B272D646A8F1
1 Fault Found:
01316 - ABS Control Module
            004 - No Signal/Communication
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000003130667
   Coding: E18A8F020004140000110D000000000000087F075C
   Shop #: WSC 20029 576 12053
   VCID: 3A712C317544B89
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 20029
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 20029
No fault code found.
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 L    HW: 1K0 909 605 L
   Component: Q4 AIRBAG VW8   025 0700
   Revision: 08025000    Serial number: 0038CD07K4N4
   Coding: 0020788
   VCID: 356B3F0D5C5A571
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
   Component: Lenksäulenmodul 021 0050
   Coding: 0002042
   VCID: 36693801415C5C9
   Part No: XXXXXXXXXXX
   Component: Lenkradmodul    007 0050
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 941 D
   Component: KOMBIINSTRUMENT VD1 0918
   Coding: 0003401
   Shop #: WSC 00558 210 00001
   VCID: 387536394B48AA9
1 Fault Found:
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 290010541486A2
   Coding: 3D3F0748072303
   VCID: 2953E37D80E2031
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 38
                    Reset counter: 137
                    Mileage: 207033 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:33:22
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 0918
Address 37: Navigation        Labels: 1T0-919-887.lbl
   Part No: 1Z0 919 887
   Component:      Navigation     0309
   Coding: 0000002
   VCID: 050B8FCD4C3A071
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2346
   Coding: 0000758
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.2       1502
   VCID: 31630B1DA8327B1
2 Faults Found:
00625 - Vehicle Speed Signal
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Mileage: 7000 km
                    Temperature: 17.0°C
                    Voltage: 14.10 V
                    Voltage: 14.00 V
00778 - Steering Angle Sensor (G85)
            000 -  -
             Freeze Frame:
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01D002007F2D8505485F861004CC
   VCID: 79F3F33D30C2731
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Component:       NGS n.mounted
2 Faults Found:
01134 - Alarm Horn (H12)
01312 - Powertrain Data Bus
            013 - Check DTC Memory
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000758
   VCID: 377735054656A51
Address 56: Radio        Labels: None
   VCID: 55AB9F8DBC1A771
No Faults Found
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2405
   Coding: 0000144
   VCID: 32610411AD34409
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
   VCID: 336F0115522E491
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End   ---------------------------------------------------------------------
check the fuses for the ABS first
Thanks Eddie nl tried this. Wall check out ok. Wouldn't that give me an abs warning light?
Sent from my HTC One using Tapatalk
