EML and flashing glow plug
Hi
my eml came on yesterday, with the glow plug flashing.
A scan shows the following: Apologies for the lengthy post:)
               Address 01: Engine       Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 RD    HW: 03L 906 022 GA
  Component and/or Version: R4 2,0L EDC G000SG  5751
           Software Coding: 0001072
            Work Shop Code: WSC 73430 790 00090
                      VCID: 78F42CA10BD125DEA37-802D
3 Faults Found:
005522 - Altitude Sensor / Boost Pressure Sensor
               P1592 - 000 - Implausible Correlation - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 61301 km
                    Time Indication: 0
                    Date: 2024.14.29
                    Time: 16:22:00
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 12.54 V
                    Absolute Pres.: 999.6 mbar
                    Absolute Pres.: 1326.0 mbar
                    Temperature: 7.2°C
                    (no units): 5.0
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 61256 km
                    Time Indication: 0
                    Date: 2024.14.29
                    Time: 13:39:53
             Freeze Frame:
                    RPM: 1311 /min
                    Speed: 69.0 km/h
                    Temperature: 20.7°C
                    Absolute Pres.: 1397.4 mbar
                    (no units): 81.6
                    (no units): 1.25
                    Temperature: 89.1°C
000403 - Fuel Pressure Sensor (G247)
               P0193 - 000 - Short to Plus - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 61301 km
                    Time Indication: 0
                    Date: 2024.14.29
                    Time: 16:22:35
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 12.31 V
                    Inj. Quantity: 0.0 mg/str
                    Temperature: 29.7°C
                    Temperature: 90.0°C
                    Temperature: 36.0°C
Readiness: 1 1 0 0 0
The car drove ok, without any loss of power or limp mode.
I have cleared the codes, and no warning lights came on today after a 100 mile motorway trip.
I have a DTUK box fitted and spoke with DTUK, who seemed to think it was unrelated to the box.
The box was left off today, but I have replaced it now with the map dropped from 4,2 to 4,1. so will see if the problems reappear tomorrow
Any ideas what these codes refer to and should I be worried?
thanks
Also, there was an ABS module error code, which I assumed was down to my TPM , the light came on a couple of times in the last month due to a drop in tyre pressure
Would that cause a code to be registered against the ABS module?
thanks
Anyone?
Is it still throwing up the error without the box?
I cleared the codes and drove without box for 100 miles, no warning lights, added box back, dropped down to 4,1 and today fine again for 50 miles so far.
Not done another scan yet though
ok... so watch this space.
I had the flashing glow plug warning light at the weekend too.  I pulled over, switched the engine off and back on again and the light didn't come back on.  I've been told it could be that it needs a regen but not 100% sure.  Does that sound right???
I would have the dpf light would have come on if it was a regen.
Any idea why my glow plug light would be flashing then?
It's the "something's gone wrong" light, most probably electrical. You need to get the car scanned for faults. Look in the diagnostics forum, there is a list of people who have VCDS and can help you.
OK cheers.  It's still under warranty so will get it in for a check over.
my car did a dpf regen on saturday, as when parked it was making one hell of a racket
What does the dpf light look like then?
A rectangle full of spots with lines sticking out both ends.
Cheers for that :)
  • 4 weeks later...
well EML on again after nearly 800 miles, same fault codes except fuel pressure sensor
I am now running without box for a 1000 miles or so to see if it is the box that is the problem.
