No sound out of new radio.
Hello all, this new radio is becoming a bit of a curse. Got the code eventually and everything functions on it. Sat nav, cd changer and even when I make a call the person can hear me. I have absolutely no sound though. Is this just a connection issue or is there any canbus code I need to get done to it? I originally had a stream mp3 and this new radio is an Amundsen+. Any help would be greatly appreciated.
Is it a new unit or a "pre-loved" one?
There are some VCDS settings that possibly would stop sound from the speakers......the power-amp/sound system being ticked for example.
If I've got time I'll grab some screenshots of my settings.
That would be great. After a bit of reading I came across a thread that said the new radio could have been set up to use an external amplifier for an upgraded sound system option. And my car had a stream mp3 in it so probably doesn't have an external amplifier. It's pre loved alright, out of a crashed 2012 from a breakers yard.
That would be great if you found the screen with the settings if you get time.
Hi, had the same problem and after connecting VCDS then I programmed it to "accept" the extra speakers. So basically it a programming issue which kan be solved. Your local dealer can also help you.
Thanks for the reply. I solved it eventually. It was that there was a Nokia car kit in it with a relay box and I took out the kit and relay box and so the signal wasn't going through the contacts on the relay anymore. Stuck back in the box and it's working fine. After market wiring. Going to leave the wiring there and put back in the car kit and old radio when I go to sell it.
