Wheel questions - help from the experts please?
Hi folks
I have a twindoor FL Elegance 170 manual and am thinking about changing the wheels on it.
I have 7.5J, 18'' Trinity wheels at the mo, 5 x 112 with ET46.
The wheels i'm thinking of are 8.0J, 18'', 5 x 112 and ET45.
Will this work without any issue do you know?  ET should be fine as only 1mm but the extra 1/2 ''??
Many thanks in advance
Dave
Should be fine, the size differences is minimal.
http://www.willtheyfit.com/index.php?width=225&aspect=40&diameter=18&wheelwidth=7.5&offset=46&width2=225&aspect2=40&diameter2=18&wheelwidth2=8.0&offset2=45#content
Do you think so?  5.3mm closer to the suspension and 7.3mm further out and therfore closer to the arch?  Will this still be ok?  I tow a caravan and often have the car fully laden.  Will there be deffo be no rubbing on arch liners etc do you think?
Thanks, Dave
And (daft question perhaps) but do i need longer wheel bolts?
You may need to get the old measuring tape out and do a bit of measuring to see what tolerances you have.
