Speaker Wiring Help
Was about to install some upgraded speakers into the rear quarters on my mk1 fabia vRS. I have already done the fronts using wiring conversion harnesses and golf mk4(?) adaptor rings.
But the rears have different plugs.
Which wire is for what? I'm assuming I need to cut the block off and solder a spade connector on to fit the new speaker now. But which wire?
I thought it was going to be the same as the fronts so I had bought two pair of wiring harnesses but it seems not to be the case.
This is how my new speaker currently looks inc wiring harness
Any help would be greatly appreciated.
Not to worry people I have sorted it now :)
Guest
