Forge DV
Does the Forge DV make the whoosh sound or not?
Or is it just the Forge spacer on an Oem Dv that makes the sound?
I'm thinking best OEM DV and spacer?
But if the Forge one does 'whoosh' my hues be better quality and stronger but unsure if it has the sound?
Vag turbo engines aren't designed to run atmospheric dump valves, they run recirculating ones, so if your gonna get any sound at all it will be minimal, nothing like the sound you get on a WRX or an EVO etc
you will get some sound if you fit a induction kit :)
The subaru turbo engine, wrx and sti, are also designed to run re-circ, fitting a dump valve in place of the re-circ valves can cause nasty fueling issues, as the ECU is still fueling the the car for the air that should be there but isn't, I assume the vag engine will be the same
Newest rev and a spacer will give you the noise your after.
I run a rev D and spacer and it's pretty loud, I have an autotech intake which helps too :)
if its anything like the leon it will lose power and may even drop it into limp mode
I would say don't bother with a spacer or dump valve so you will have full recirculation. Car will hold boost better and perform better. A nice intake is all you need ! Just my 2p's worth haha
No-one answered my actual question haha!=
Forge do a FULLY DIVERTONG DIVERTOR VALVE FOR THR TFSI, my question was does it make the whoosh, guessing not because it's no atmospheric.
So the Spacer and Rev D is ' the one for whoosh' lol
Ok that's all I need to know.
And all I need is yours to be delivered Dallen75! Haha.
May get the Spacer just for the sound though, but suppose with a DP and map it'll be enough noise anyway!
You should be able to get your mapper to map the car to run the atmospheric instead of the re-circ and it'll not over-fuel
You will like the intake when it's on,plenty of whoosh and a wee bit of flutter ! Courier picking it up Tom morning 24hr delivery ok
iv never had rec on mine just a baileys and now my forge and they where and are VERY loud. just like my old Scooby and my old rst .
they HAVE to be twin piston to work though and I have never had any lights or any problems with mine all this u cant run them is rubbish.
Asif it's 24hour delivered mate that's ace!! And madmacca twin piston forge dovertor or dump??k links mate
Sure you can run These dumps and not cause problems?? Never really seen um on TFSI
He's got a mk1 not mk2.
There's no need to fork our £200 when a spacer and newest rev dv give the noise you want ;)
It is pretty loud too.
Ahh, I new you could on mk1s just thought we was on mk2s here
Well this is the mk2 forum after all :D
Sent from my Nexus 5 using Tapatalk
Putting mine bk to standard if your still looking
SNH what have you got?
