DIY RARB removal
I'm removing my RARB, but want to make sure I bolt the suspension back up properly.
Does anyone know what torque should be applied to the lower strut bolts?
4 white knuckles :)
Is it coming off tonight then ;) I'm about 3 hours from Luton
All I can find. For mk1 fabia though but it should be fine for the mk2 suspension part in question
Please find some more below from Haynes with a bit more clarity on bolt positions, and additional personal experience notes. I am not liable for any of this (covering my own back)!!! http://ww1.briskoda.net/forums/public/style_emoticons/#EMO_DIR#/emoticon-0122-itwasntme.gif
PETROL ENGINE GENERAL
Spark plugs = 30Nm (22lbf ft)
Sump drain plug = 30Nm (22lbf ft)
Manual gearbox filler & drain plugs = 25Nm (18lbf ft)
Road wheel bolts = 120Nm (89lbf ft). Tighten up in diagonal cross pattern.
PETROL ENGINE 1.4MPI
Rocker cover bolts for 1.4MPI = 3Nm (2lbf ft)
FRONT SUSPENSION:
ARB saddle clamp over bush = 20Nm (15lbf ft)+ 1/4 turn. The lower bolt on the drivers side cannot be reached with the wheels in the air as the angle of the drive-shaft covers the bolt, so do this bolt first when undoing, and last when tightening, and jack the wishbone up on this side under the ball-joint to raise the drive-shaft out of the way!!
ARB drop link both ends = 40Nm (30lbf ft) Do not fully tighten top (strut) end until car is fully supported (evenly) on wheels! Always renew the nuts.
Balljoint to lower arm = 20Nm (15lbf ft)+ 1/4 turn These are the three small bolts, only resuse the captive tri-nut plate twice, and reuse the bolts no more than three times!
Balljoint to hub carrier nut = 20Nm (15lbf ft)+ 1/4 turn, Always renew nut.
Front pivot bolt for lower wishbone = 70Nm (52lbf ft)+ 1/4 turn.
Lower arm rear mounting bracket plate (console) has 1 large bolt and 2 small ones.
Large = 70Nm (52lbf ft)+ 1/4 turn.
Small = 20Nm (15lbf ft)+ 1/4 turn. Always renew these bolts.
Front (console) subframe to underbody bolt (the one that you get to through hole on wishbone) = 50Nm (37lbf ft)+ 1/4 turn (Yes I know that this is a lower torque than rear bolt, but logically the rear one takes more force as the suspension tries to go up and back into bodywork, which is why it also has a reinforcing place and a further 2 bolts!!
Steering rack to subframe/console/underbody (four bolts) = 50Nm (37lbf ft)+ 1/4 turn.
Gearbox link to subframe bolt = 40Nm (30lbf ft)+ 1/4 turn.
***If you have had to move/replace console, ARB, etc. I have found this to help setting it up even!! Slacken all the above bolts up to line ******(especially front pivot). Then push the aluminium consoles (you might also have to push the subframe) to rear of car and outwards max diff is about 5mm. Then fully tighten the rear console bracket bolts (6 total) and front console bolts (2). Then tighten (evenly) the front pivot bolts to 1/2 torque (this positions the sub frame), then fully tighten the four steering rack bolts. Now you can go back and fully tighten the front pivot bolts, and the gearbox link to subframe bolt!!!
Suspension strut bottom clamp bolt & nut = 60Nm (44lbf ft)+ 1/4 turn. Always renew nut.
Piston rod nut to top mounting = 60Nm (44lbf ft) Always renew nut.
Top mounting bolts to bodywork (three of) = 15Nm (11lbf ft)+ 1/4 turn. Always renew.
Main 12 point hub nut (all older types should be replaced with this type) = 50Nm (37lbf ft)+ 1/8 turn (45 deg. Use once only design!!) Tighten the nut up just enough to fully draw the driveshaft into the bearing unit, refit the wheel (do not fully tighten the five wheel bolts, wheel should not move, and no gap between wheel and hub), then put car on ground, then fully tighten the main hub nut, then fully tighten the wheel bolts in diagonal cross pattern!!
REAR SUSPENSION:
Main pivot bush through bolt & nut = 45Nm (33lbf ft)+ 1/4 turn. Always renew nut. These should be done up so that they just touch the mounting bracket, then refit wheels etc. and lower car to ground. Open hatch and bounce car up and down from centre of hatch lower lip (this settles the bushes). Now you can fully tighten the bolts up (leave the car on ground!!)
Piston strut to beam bottom mounting bolt & nut = 40Nm (30lbf ft)+ 1/4 turn. Always renew nut. These should be done up so that they just touch the mounting bracket, then refit wheels etc. and lower car to ground. Open hatch and bounce car up and down from centre of hatch lower lip (this settles the bushes in piston mounting). Now you can fully tighten the bolts up (leave the car on ground!!)
Piston rod nut to top mounting = 25Nm (18lbf ft)
Top mounting bracket to bodywork bolts(two of) = 30Nm (22lbf ft)+ 1/4 turn. Always renew.
Stub axle bolts (four off) = 30Nm (22lbf ft)+ 1/4 turn. Always renew.
Main 12 point hub nut = 70Nm (52lbf ft)+ 1/12 turn (30 deg). Always renew. This one doesn't need car to be on ground etc. like front one!!
FRONT BRAKES:
Guide pin bolts for FSII & FSIII calipers = 28Nm (21lbf ft). Always copper grease for bushes and use "blue" threadlock on threads!
Guide pin bolts for C54-II caliper = 30Nm (22lbf ft). Always renew.
Mounting bracket bolts for C54-II caliper = 125Nm (92lbf ft).
Brake disc splash shield bolts = 10Nm (7lbf ft).
Brake disc = none given, older VW used to state low value of around 10Nm (7lbf ft).
REAR DISC BRAKES:
Guide pin bolts = 35Nm (26lbf ft). These need to be counter held to stop rotation and "blue" threadlock on threads.
Mounting bracket bolts = 30Nm (22lbf ft)+ 1/12 turn (30 deg), and "blue" threadlock on threads.
DIESEL ENGINE MOUNTINGS INC. VRS!
Drivers side engine mounting to;
Engine = 30Nm (22lbf ft) + 1/4 turn
Body = 20Nm (15lbf ft) + 1/4 turn
Centre nut = 40Nm (30lft ft) + 1/4 turn
Passenger side mounting to;
Transmission = 40Nm (30lft ft) + 1/4 turn
Body = 50Nm (37lbf ft) + 1/4 turn
Rear torque arm to;
Subframe = 40Nm (30lft ft) + 1/4 turn
Transmission = 30Nm (22lbf ft) + 1/4 turn
1.4lt 16v PETROL ENGINE MOUNTINGS
Engine = 20Nm (15lbf ft) + 1/4 turn
Body = 30Nm (22lbf ft) + 1/4 turn
Rear torque arm to;
4 white knuckles :)
Not tonight I'm afraid. Just getting my facts lined up for tomorrow's bleeding knuckles session :)
