Bolero / Bluetooth coding help
Hi all,
Can you help me with some coding issues?
I've got the below details from a scan but don't know how to fix them? Particularly the telephone not being registered?
I'll be removing the unit and refitting the wires to clear up the errors logged around intermittent signals etc and must've knocked the interior light when fitting the mic!
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Not registered 0011
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 AD    HW: 1K0 937 087 AD
   Component: BCM PQ35  H   111 0709
   Revision: AC111709
   Coding: 48000AB8A05BB1C040080080110001E4430000AE524D8160808540040040
   Shop #: WSC 73430 790 00097
   VCID: 73EE6BEED262538696F-8026
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 04101  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
1 Fault Found:
00059 - Terminal 30 for Interior Lighting
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 29914 km
                    Time Indication: 0
                    Date: 2020.14.29
                    Time: 10:45:45
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.30 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AB    HW: 7N0 907 530 AB
   Component: J533  Gateway H47 1633
   Revision:   H47       Serial number: 200912F2003256
   Coding: 352303
   VCID: 70E464E2A374689E6BD-8025
4 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 133
                    Mileage: 29594 km
                    Time Indication: 0
                    Date: 2020.14.16
                    Time: 16:42:37
00469 - Infotainment Databus in Single Wire Operation
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 10
                    Reset counter: 133
                    Mileage: 29914 km
                    Time Indication: 0
                    Date: 2020.14.29
                    Time: 11:16:32
01304 - Radio
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 124
                    Mileage: 29594 km
                    Time Indication: 0
                    Date: 2020.14.16
                    Time: 16:47:40
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 53
                    Reset counter: 255
                    Mileage: 29594 km
                    Time Indication: 0
                    Date: 2020.14.16
                    Time: 16:45:07
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 M    HW: 1Z0 035 156 M
   Component: BOLERO        001 0008
   Revision: -----08S    Serial number: SKZ4Z3M1170271
   Coding: 0D0004000001
   VCID: 3C7C80D2BFBCDCFE875-8069
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 133
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
00849 - S-contact at Ignition/Starter Switch (D)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 124
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669499229
   Coding: 0A00000101010101
   Shop #: WSC 01357 011 00200
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 244C58B22F0C843EDF5-8071
5 Faults Found:
9455635 - Telephone Microphone
          B1048 13 [008] - Open Circuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 133
9457427 - Left audio channel for speech/telephone
          B104F 13 [008] - Short to GND
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 19
                    Reset counter: 138
                    Mileage: 29914 km
                    Date: 2020.14.29
                    Time: 12:12:16
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 29914 km
                    Date: 2020.14.29
                    Time: 12:12:14
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 84
0022 - Radio
          U1066 00 [008] - No Communication
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 124
                    Mileage: 29594 km
                    Date: 2020.14.16
                    Time: 16:47:35
End   ---------------------------------------------------------------------
Do things work?
Have you cleared the fault codes to see if they return?
The lights aren't working (I think I've blown the fuse).
The phone isn't working properly. The phone connects but the media streaming doesn't work.
Hmm fuses look fine in the car. Could it be a fuse other than 15?!
