fault codes, any ideas
Evening
Once again asking the lovely people of this forum for a little advice.  Car is idling a little rough and for the past 2 days has revved slowly of its own accord up to 1500 and slowly dropped back down.  May even have been running a little rough at lowish revs, but barely noticeably.  Seems well behaved enough under acceleration.
Scanned today, report below.
My clumsy googling suggests either pcv, and/or a leak in the intake system somewhere.  Any other ideas?
Gar will be dropped in to a garage as soon as practical,  should I insist any parts are replaced first?
Assuming the garage agree I was looking at pcv & fuel filter to start.
Thanks all
Simon
Tuesday,21,October,2014,17:57:24:50621
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: TMBEF21Z982109781   License Plate: SKODA
Mileage: 128120km-79610mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBEF21Z982109781   Mileage: 128120km/79610miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1Z0 907 115 D    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: SKZ7Z0G4515416
   Coding: 0203000318070060
   Shop #: WSC 00191 264 15243
   VCID: 36633C264182C0AE71B-8063
3 Faults Found:
008825 - Leak in Air Intake System
               P2279 - 002 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 128009 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:58:57
             Freeze Frame:
                    RPM: 1363 /min
                    Load: 11.8 %
                    Speed: 0.0 km/h
                    Temperature: 92.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected. - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 128071 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:22:13
             Freeze Frame:
                    RPM: 1372 /min
                    Load: 11.8 %
                    Speed: 0.0 km/h
                    Temperature: 92.0°C
                    Temperature: 26.0°C
                    Voltage: 14.351 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 128071 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:22:32
             Freeze Frame:
                    RPM: 806 /min
                    Load: 16.5 %
                    Speed: 6.0 km/h
                    Temperature: 66.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 73430 790 00000
   VCID: 73E5C53212709586965-8026
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 AB    HW: 1Z0 907 044 AB
   Component: ClimatronicPQ35 120 0600
   Revision: 00120022    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 76E3FC26010280AEB1B-8023
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005453036
   Coding: 018C0F011004140040110D000000000000087F075C000000000000000000
   VCID: 71E9CF3A686CA796649-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 121207 022  0601
   Coding: 00055223
   Shop #: WSC 73430
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1NPDG+
   Coding: 0020788
   VCID: 3D71230A64B413F6B01-8068
   Subsystem 1 - Serial number: 6332MSME37146659C
   Subsystem 2 - Serial number: 6342MSME37146F53G
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Component: J0527           051 0100
   Coding: 0000012
   VCID: 7F0D19022E38C1E6E2D-802A
6 Faults Found:
00576 - Terminal 15
            012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 C    HW: 1Z0 920 912 C
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610056    Serial number: SKZ7Z0G4515416
   Coding: 0003401
   Shop #: WSC 26041 067 57207
   VCID: 35613B2A5C84CBB6781-8060
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 141
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0191
   Revision:   H16       Serial number: 2000K07C170973
   Coding: E9807F060002021303
   VCID: 3467062E57FED2BE4FF-8061
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000756
   VCID: 387F321E4B9636DE637-806D
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 73430 000 90108
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81801A085283007F3F04850540085F96907CA0
   VCID: 830515F2C2D02506065-80D6
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H07 9001
   Subsystem 7 - Component:       NGS n.mounted
2 Faults Found:
01038 - Central Locking Thermal Protection
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 4
                    Fault Frequency: 8
                    Reset counter: 114
                    Mileage: 127725 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:43:34
01135 - Interior Monitoring Sensors
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 124
                    Time Indication: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000756
   VCID: 3979371A709C2FD69C9-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0040
   Revision: 00019000    Serial number: SKZ7Z3G0130146
   Coding: 0000402
   VCID: 2E531446B9D2F86E39B-807B
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 377D3122468839A66AD-8062
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Component: Tuer-SG         006 1301
   Coding: 0000144
End   ---------------------------------------------------------------------
when my vrs did this it was the pcv pressure control valve located under air box. 141435523562_1.jpg
Thanks, expensive fix?
0843 3080 555.................... £32.00 delivered plenty on bay takes about 10 minutes to do, Hardest part getting air box off warm engine first seems to be easier.
Have you used the Ross-Tech site to search for your fault codes?
This site lists common symptoms, likely causes and suggestions on how to fix for all VAG fault codes...
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
yeah, I ended up there last night via a general google search for the fault codes.  All 3 point back possible air intake leaks.  The general googling did also point me in the pcv direction before
kidology said the same, I didnt want to prejudice peoples advice by pulling that one out of the air.
Anyway its booked in for the techies to look at tomorrow, hopefully a quick easy fix and will be back to full capability this time tomorrow.
Pcv replaced and appears to be back to its normal self. Thanks kidology. Interestingly the garage I took it to were quite non comittal about whether the pcv would fix it.
Glad your all fixed mine rattled when i took it off.
  • 4 weeks later...
So, 1 month down the line and another fault  :envy:
Driving along, then a serious power loss, but still drivable.  Car was back to normal the next morning, then did the same later that day.  Again fine in the morning and has been since.  Slightly hesitant and slightly down on mpg maybe.
Scan is below, and if I am reading this correctly then this is the wiki ... http://wiki.ross-tech.com/wiki/index.php/16618/P0234/000564
  • Hoses incorrectly connected, disconnected, blocked or leaking
  • Boost Pressure Control Valve (N75) faulty
  • Boost Pressure Sensor (G31) faulty
  • Turbo Charger stuck/faulty
N75 valves look cheap, so would replacing that be the sensible first step?  are the rest of the suggestions easy for a garage to test?
cheers for any advice
Simon
