esp/abs pump dead
hi all ... well what a headache , abs pump pressure sensor dead , 2nd hand pump fitted ( full unit ) wont run or bleed on the car , pump removed and my old elecs fitted to the 2nd hand switch side of the unit , re fitted to car and still nothing !! wont run with vag.com ... could it have lost its coding ?? is the pump on a relay or just a fuse ?? help !
what year is your car
What pump did you have, and what have you fitted?
2005 2.0 diesel 140hp same pump fitted ,taken off
1ko 614 117 h
