clutch sprung up.
Wonder if anyone could help,my clutch pedal snapped about 3 months ago and had it welded and was as good as new but today I pressed the clutch and as I released the clutch pedal sprung up about an inch to 2 above the correct level the car still drives perfect just a raised springy clutch.any advice is appreciated.
Hi ,
Have you checked the cable itself for any sign of wear etc
It could of just made itself loose at either end ..
Hope this helps [emoji2]
Something just clicked like plastic snapping but no sign of any break.i had new cylinder at back of clutch pedal.im not mechanically minded so not sure haha
Hmm interesting...
I would just look at the pedal end of the clutch cable and see if there is any parts missing [emoji57]
If one of your mates has a mk4 golf , bora or Passat have a look at there setup behind the pedal , you could be missing something
There is no cable the clutch is hydraulic. IIRC there is a plastic part up where the pedal hinges that commonly breaks causing what you've described.
Edited by pauldazzle
I've had a look in the dark haha but Yeh where my pedal was welded looks like a white clip is looking a bit worse for wear.cheers for that pauldazzle and peterbrady
Edited by norby822
Mine white clip partially broke after I had the clutch welded and clutch was higher. So I just replaced the white clip and it's been fine since.
