Fabia Aerial replacement - please help!
Hi, sorry I can see this has been asked before but I need some clarification. I recently bought an 08 fabia 1.2 hpt (70) and the radio reception is awful. I'd like to put a shark fin aerial on but I don't know what to buy. Could someone please advice? With links or products you have used if possible? Thank you :)
Shark fin will undoubtedly make it worse in afraid. Does your car have an after market radio fitted by any chance?? If so you need to get a signal booster fitted.
Why do you want a shark fun? In hope to boost signal or for aesthetic reasons?
I'm guessing you have the dance head unit.
Press and hold the menu button for 10 secs until the screen changes, at the top left you will see ANT (antenna or aerial) ON or OFF / EIN or AUS. If ANT is OFF then there is a fault in the aerial base or possible in the lead from the aerial to the head unit.
