Self Levelling Headlights - not self levelling
Hi all,
i have a 06 superb, 1.9 awx, edition 100 model.
The self levelling headlights stopped working a while ago, both sensors on front and rear axels are within their permitted ranges.
Been to a few garages and cant get a solution
Heres the log:
Wednesday,25,February,2015,17:12:38:36966
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1
Data version: 20150130
Mileage: 212900km-132289mi   Repair Order:
Chassis Type: 3U (3U - Skoda Superb (2002 > 2008))
Scan: 01 02 03 08 15 16 17 19 36 37 46 47 55 56 76
VIN: TMBBU63U569103692   Mileage: 212900km-132289miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 KE
   Component: 1,9l R4 EDC G000SG  4898
   Coding: 00005
   Shop #: WSC 00028
   VCID: 64CC8FBFF4CBD901EA8-4A9C
   TMBBU63U569103692     SKZ7Z0E3029782
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 3U0-614-517.lbl
   Part No: 3U0 614 517 D
   Component: ABS/ESP front       1314
   Coding: 04255
   Shop #: WSC 00028
   VCID: 346C3FFF04AB0981BA8-50C8
Address 08: Auto HVAC        Labels: 3U0-907-044.lbl
   Part No: 3U0 907 044 A
   Component: CLIMATRONIC S B5 C  2004
   Coding: 17000
   Shop #: WSC 00028
   VCID: 316236EBFBB93CA9D1E-50E6
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 F
   Component: 0D AIRBAG VW61 0K   0003
   Coding: 12356
   Shop #: WSC 00028
   VCID: 2756D8B3C57D72190FA-50AC
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 3U0 907 487 A
   Component: Lenkradelektronik   0002
   Coding: 00001
   Shop #: WSC 00028
   VCID: 3C7C17DF2CFBC1C1728-50C8
Address 17: Instruments        Labels: 3U0-920-xxx-17.lbl
   Part No: 3U0 920 941 A
   Component: KOMBI+WEGFAHRSP VDO V06
   Coding: 31425
   Shop #: WSC 00000
   VCID: 326039E7FEBF07B1A84-50AC
1 Fault Found:
01336 - Company Data Bus for Comfort System
            49-10 - No Communications - Intermittent
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70E4F3EF303375A19E0-50AC
1 Fault Found:
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: °301
   Shop #: WSC 00000 065 00000
   VCID: 2F663093BD8D2A59C7A-50C8
1 Fault Found:
01008 - Note; Emergency OFF Switch is Active!
            000 -  -  - Intermittent
Address 37: Navigation        Labels: 3B0-919-887.lbl
   Part No: 1U0 919 887 B
   Component: Navigation     BNO 0102
   Coding: 00002
   Shop #: WSC 00028
   VCID: 428069274E1FB731384-4A82
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: EB Komfortgerát HLO 0004
   Coding: 00258
   Shop #: WSC 00028
   VCID: 366805F712D71B9184C-4A9C
   Subsystem 1 - Part No: 1C0959802
   Component: EB Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C0959801A
   Component: EB Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 3U0959811
   Component: EB Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 3U0959812
   Component: EB Tõrsteuer.HR KLO 0202
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
            27-10 - Implausible Signal - Intermittent
Address 47: Sound System        Labels: 1J0-035-456.lbl
   Part No: 3U0 035 456 B
   Component: Soundprozessor 3   0002
   Coding: 00572
   Shop #: WSC 00028
   VCID: 316236EBFBB93CA9D1E-4A6A
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00005
   Shop #: WSC 25083
   VCID: 040CAF3F148B79014A8-4AB4
2 Faults Found:
01539 - Headlights Not Adjusted
            35-00 -  -
65535 - Internal Control Module Memory Error
            00-00 -  -
Address 56: Radio        Labels: 3B0-035-186.lbl
   Part No: 3B0 035 186 D
   Component: Radio          BNO 0102
   Coding: 00027
   Shop #: WSC 00028
   VCID: 2044C3AFA05385214E0-4A82
Address 76: Park Assist        Labels: 3U0-919-283-7X1.lbl
   Part No: 3U0 919 283 A
   Component: Einparkhilfe        V002
   Coding: 00114
   Shop #: WSC 00028
   VCID: 39720ECB23C9F4E969E-4AB4
1 Fault Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            03-00 - No Signal
End-------------------------(Elapsed Time: 03:13)--------------------------
Can anyone help?
thanks
Dermot
I had the same error 2 years ago (VCDS error 65535 Address 55) and it was the dynamic range module (LWR in German), which is located in the left side of the trunk, beneath the carpet. Unfortunately cannot be fixed, you have to change it, new ones are quite expensive, but alternatives can be found on eBay (sh, from dismantled donor cars - fits from Audi, Vw, Skoda, part code you can use from diagnosis 4Z7-...)
Good luck.
Trimis de pe al meu D5503 folosind Tapatalk
