A couple of OPS questions if I may..
Hi All
I have a 2014 Fabia vRS estate and I have bought the OEM OPS rear PDC kit and just wondered if you could answer the following?
1 Where should the control module be mounted? The loom passes through from the sensors in the bumper the through the large hole behind the crash bar, sealed with the rubber grommet then off to the control module. I just want to mount it where it normally should be
2 Where should the speaker for the pdc be mounted?
3 Where is the canbus gateway located? The kit comes with wiring to take the signal from the control unit to the CAN BUS gateway so I can then get my HU programmed to show the graphic.
Many thanks in advance
