Help with codes following scan
Hi,
I had the car scanned today and it has bought up the following codes.
1 thing is that the rear window works backwards ?
does this mean I need new motor or maybe central convince module?
all help will be gratefully accepted
Saturday,20,June,2015,15:09:43:28876
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
www.Ross-Tech.com
VIN: TMBUH21Z672140071   License Plate: OY07 NRF_NEXT
Mileage: 178340km-110815mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBUH21Z672140071   Mileage: 178340km-110815miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 EL    HW: 03G 906 018 EL
   Component: R4 2.0l PPD1.2 G    9953
   Revision: --H42---    Serial number: SKZ7Z0G4047329
   Coding: 0000072
   Shop #: WSC 25073 576 93589
   VCID: 73E245F412C5E4B963D-8026
1 Fault Found:
005785 - Powertrain Data Bus
               P1699 - 009 - Missing Message from Steering Wheel Electronics - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 178338 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:16:19
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 136.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 13.22 V
                    Bin. Bits: 01000010
                    Bin. Bits: 00000000
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0006786
   Shop #: WSC 73430 790 00000
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 M    HW: 1Z0 907 044 M
   Component: ClimatronicPQ35 110 0400
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 4088DA3813F30F212EF-8015
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004741898
   Coding: 01880F030004140000110D000000000000087F075C0000
   VCID: 6CD05E884FFB3B41A27-8039
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 030307 022  0601
   Coding: 00055223
   Shop #: WSC 73430
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD13TL5M
   Coding: 0020788
   VCID: 3D76A3CC640162C9459-8068
   Subsystem 1 - Serial number: 6332MSME171C3756D
   Subsystem 2 - Serial number: 6342MSME163B1E40C
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
   VCID: 74E046E817CBE3817A7-8021
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -  - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 E    HW: 1Z0 920 912 E
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610056    Serial number: SKZ7Z0G4047329
   Coding: 0001401
   VCID: 377AB1E4463D48999F5-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 150307F1001141
   Coding: 3D3F034007002303
   VCID: 2F6A8984BE6D8059C75-807A
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000756
   VCID: 3878B2D84B2347E196F-806D
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 73430 000 90108
   VCID: 3566BBEC5C31BA898D9-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0203
   Revision: 00020000    Serial number: 00000000000000
   Coding: 98801A085283007F3F04850540085F96907CA0
   VCID: 030215344265D43973D-8056
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE No Answer
2 Faults Found:
01135 - Interior Monitoring Sensors
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 13
                    Reset counter: 235
                    Mileage: 165370 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:50:53
01134 - Alarm Horn (H12)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 9
                    Reset counter: 235
                    Time Indication: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000756
   VCID: 397EB7DC70295EE9691-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       020 0041
   Revision: 00020000    Serial number: SKZ7Z3J0153855
   Coding: 0040402
   Shop #: WSC 22029 576 94908
   VCID: 2E549480B9678951CC3-807B
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000192
   Shop #: WSC 73430 790 1012544
2 Faults Found:
            005 - No or Incorrect Basic Setting / Adaptation
00102 - Rear Left Interior Locking Button (E310)
            008 - Implausible Signal
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000192
3 Faults Found:
00123 - Outside Warning Light/Door exit Light; Rear Right
            012 - Electrical Fault in Circuit
00103 - Rear Right Interior Locking Button (E311)
End-------------------------(Elapsed Time: 01:27)--------------------------
We're all codes saved then cleared and rescanned? I've seen a few of them codes for various things like battery disconnected and incorrect coding on my part. Clear them all I'd say and try again. Some of them may be very old. I may be wrong but lots look like bad coding for things that are not present.
They were all cleared and rescanned, going to try recoding it all with one of the guys fr here hopefully it works :s
Where abouts are you, plenty of good guys on here could help
Dgb400 is going to do it this week hopefully it sorts it if not back to the drawing board
coding and basic settings should rid you of a few of those issues.
interior monitoring sensors need the sensitivity turning down and the alarm horn needs new batteries or replacing.
  • 8 months later...
