2015 Superb headlamps
Are they all xenon?
I thought only Elegance and L&K’s got Xenon’s as std?
Well Europarts list ONLY Xenon, c/w washer, £350
No one knows - that's a long way in the future.
Unless you meant 2015 Superb models, in which case as Gizmo68 says above.
:D
Didn’t notice it said 2105! (I have changed it now)
There is halogen and bi-xenon.
Both use projectors for dipped headlights though (the same as the MkII pre-FL).
These are the halogens, note the indicator is a non-LED bulb and the DRL's (again non-LED) are inboard of the dipped projectors (main beam bulb at reduced brightness)...
01_Bi-xenon-headlights-with-dynamic-angl
The bi-xenon lights get LED DRL's (over the top of the (LED) indicators). The inboard bulb performs the flash function...
skoda-superb-estate-6-headlight.jpg?itok
to upgrade to the full Xenon you need a power pack i believe?
and a LOT of money
Yeah, the xenon's also get self leveling (sensors on the suspension) and the headlight wash system, plus as you mention the igniters and ballasts, as well as the £80 bulbs.
Not a cheap retrofit.
Given the replacement costs id avoid a car with them, my Epica had some high output bulbs (£24 each) which sounded dear to me
Thats a pre FL light
Once you have had xenon’s there is no going back!
11221337_1023340707678843_35706947631666
+ 1 for definitely from me. I have had xenon's for the last 7 years and will always go for them.
Completely agree here. Had them since my 08 Octavia and definitely couldn't go back. Have a bit of time recently in cars with halogen lights and its like having two candles lighting up the road!
My deciding working nights wasnt for me probably the best thing then...lol
what uprated bulbs will my car stand without blowing CANBUS?
Edited by lichfielddriver
DOH...
My DRL option uses the headlamp, all the foglamps on ebay come "inc DRL"
can i use 1 and ignore the DRL?
No, the foglights with DRL are pre-FL (pictured below), on your FL model the foglights are a different shape and are foglights only (plus cornering function if enabled).
Its getting headlamp and foglamp tomorrow, assuming the right ones turn up, Skoda know which are right but repairers dont always use OE parts
