Steering Controller
Hi All
My 08 PD VRs indicators, wipers and main beam head light have either stopped working completely for a while and then work briefly. I've scanned it for codes and I get: Address 16: Steering wheel Cannot be reached! I believe both indicator and light stalks are connected to the steering controller.
Presumably the steering wheel needs to come off to access the controller, how easy is this? I've looked online and in the forums and all seem to say it's realtively easy to do! But for the life of me I can't see where to stick a screwdriver to release the airbag etc!! As I'm knocking on in years a bit of guidance would be appreciated!!
I've checked all fuses etc. and everything seems ok.
The full scan is posted below.
Saturday,07,November,2015,08:31:18:63044
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
www.Ross-Tech.com
VIN: TMBUH21Z082164609   License Plate: HK08HGL
Mileage: 139820km-86880mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBUH21Z082164609   Mileage: 139820km-86880miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 EL    HW: 03G 906 018 EL
   Component: R4 2.0l PPD1.2 G    9953
   Revision: --H52---    Serial number: SKZ7Z0H4761941
   Coding: 0000072
   Shop #: WSC 25056 576 92340
   VCID: 73CB119412436CA65B-8026
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0006786
   Shop #: WSC 73430 790 00000
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 AB    HW: 1Z0 907 044 AB
   Component: ClimatronicPQ35 120 0600
   Revision: 00120022    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 76CD28800131798E7C-8022
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
            000 -  -  - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005705186
   Coding: A1880F011004140043110D000000000000087F075C00000C000000000000
   Shop #: WSC 25056 576 92345
   VCID: 71C71B9C685F5EB6A9-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 040408 022  0601
   Coding: 00055223
   Shop #: WSC 25056
1 Fault Found:
00093 - Terminal 15 for Starting Relevant Consumers
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 252
                    Mileage: 139814 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1XP82W
   Coding: 0020788
   VCID: 3D5FF7AC6487EAD67D-8068
   Subsystem 1 - Serial number: 6332MSME3514780ED
   Subsystem 2 - Serial number: 6342MSME36010E2FD
Cannot be reached
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 E    HW: 1Z0 920 912 E
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610056    Serial number: SKZ7Z0H4761941
   Coding: 0001401
   Shop #: WSC 00581 210 64475
   VCID: 3753E58446BBC086A7-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K084030A3C
   Coding: E9807F064002022303
   VCID: 3449D28857CD2B9E82-8060
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 A    HW: 1Z0 035 680 A
   Component: RNS-MID       H05 2764
   Revision: AB001001    Serial number: SKZ6Z7H7236003
   Coding: 060004000404000300
   VCID: 2E7DC0E079E1014EF4-807A
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 254
                    Reset counter: 252
                    Mileage: 113472 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:01:55
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000756
   VCID: 3851E6B84BA5CFFEAE-806C
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 73430 000 90108
   VCID: 364DE88041B1398EBC-8062
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81801A085283007F3F04850540085F96907CA0
   VCID: 032B415442E35C264B-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000756
   VCID: 3957E3BC70AFD6F651-806C
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 252
                    Mileage: 113472 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:01:55
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
End-------------------------(Elapsed Time: 01:19)--------------------------
Saturday,07,November,2015,15:45:05:63044
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
08-Auto HVAC -- Status: OK 0000
   Coding: 0000072
   VCID: 73CB119412436CA650-8026
Readiness: N/A
   Revision: 00H11001
   Coding: 0006786
   VCID: 76CD28800131798E77-8022
   VCID: 71C71B9C685F5EB6A2-8024
   Coding: 00055223
   Shop #: WSC 25056
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 253
                    Mileage: 139821 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 14.10 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
   Coding: 0020788
   VCID: 3D5FF7AC6487EAD676-8068
Cannot be reached
   Coding: 0001401
   VCID: 3753E58446BBC086AC-8062
   Coding: 0001401
   VCID: 3449D28857CD2B9E89-8060
   VCID: 2E7DC0E079E1014EFF-807A
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 252
                    Mileage: 113472 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:01:55
   Coding: 0000756
   VCID: 3851E6B84BA5CFFEA5-806C
   VCID: 364DE88041B1398EB7-8062
   VCID: 032B415442E35C2640-8056
   Coding: 00000000
   Shop #: WSC 73430
   Coding: 0000756
   VCID: 3957E3BC70AFD6F65A-806C
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 252
                    Mileage: 113472 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:01:55
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 01:18)--------------------------
