Dial up fail
Hi guys I've had this happen to twice in two days where I tried to call someone on my iPhone 4s by press the button on the steering wheel, but this message come up saying dial up fail, then the car will disconnect the Bluetooth to my iPhone but my iPhone will carry on ringing the person any advice
Thanks from wil_nfs
not come across this I'm afraid , so i cant help... I use an iphone 5 and it works well, hasn't ever disconnected... maybe someone else will come alone with an answer
I occasionally get this with my Note3 not exactly the same as the BT does not disconnect but it will say Dial up Failed but the music will not restart and then all of a sudden, about 30 seconds later, it will start ringing through the speakers. I have found this happens when I don't have a decent signal. Don't know if you can relate any of this to your problem?
my streamed music fails after a call, and i have to go back to voice command "music" "play" to get it back....
I have had the odd occasion where my mdi says is not connect even when my iPhone is connected the mdi
