TDI cr170 Dogbone
Has anyone with a cr170 engine Poly-bushed the dogbone mount?
Feedback please!
I poly bushed (insert into the original bush) my FL CR170 DSG but had to remove it as I could not line with the excessive Noise  / Vibration it cause.  I did try it on my FL TSI manual and still didn't like it.  If I were you I would stay clear of the insert type.
Thanks!
I did alot of searching on google,and found everyone had the same problems.wish i had the older style dogbone.
Im going to try an L shape bracket which just pushes up.hopefully it will still be like OEM just tighter,until i get nice weather to drop the subframe.
