over heating
Hi can anyone help I think that my head gasket has gone on my mk2 skoda octavia,
The heaters are blowing cold all the time and the temp is fine until you go on a motorway then It goes up
Do anyone know a rough idea of what it's going to cost to have done
Considerably more than a coolant gas analysis to confirm that it is HGF rather than a water leak.
Could this not simply be a sticky thermostat?
There have been a number of complaints about the thermostats on older cars...
How would I go about testing if it is just a sticky thermostat
Pull the thermostat out of the car, pop it in a pan then pop said pan on the cooker and turn it on. Pop a thermomertor in as well. The thermostat should open about 80 dergree.
Pull the thermostat out of the car, pop it in a pan then pop said pan on the cooker and turn it on. Pop a thermometer in as well. The thermostat should start to open about 80 degree C and be fully open at about 95.
Corrections in-line
Edited by KenONeill
Cheers Ken :)
  • 4 weeks later...
stuck thermostat would overheat engine, right?
I used to have problem with oil overheating and problem was clogged water radiator
