Wiring loom route - tow bar
Started on the fitting of the tow bar. This tow bar it self was done last week with the control box and electrical coiled up in the nearside of boot at the moment. Before I start pulling off trim panels etc. Can someone confirm the route of the cabling to the offside dash beneath the steering wheel. I am assuming that it goes across the rear footwell via some kind of wiring tunnel so will need to pull back the rear carpet, remove the both lower trims in the rear, the pillar trim by the drivers seat and front off side lower trim before taking it up to the fuse box.
Thanks in advance.
All fitted and working now. I ran the cables over the rear near side wheel arch, under the insulation beneath the carpet just in front of the rear seats then down the drivers side. Still had a good 12inch excess cable when all fitted.
