Rcd510 dab freezes when pairing phone
Installed a second hand rcd510 dab in my Fabia.
Everything works well except an annoying little thing: When I start the car, the dab radio starts up as it should. The car then pairs with the phone, there's the usual beep, but once the pairing is complete, sound from the radio is gone and none of the touch screen buttons work. I can see them react when I touch them but they don't actually do anything.
If I change input to fm radio I get sound and everything appears back to normal. Switching back to dab also works.
Any ideas? Coding needed?
Edited by Aslak
Correction: This happens no matter which input I'm on. Tried with FM-radio this morning. Same issue. Switching to another input fixes the problem still.
Yet another correction... This has nothing to do with pairing apparently. It happened just now when I didn't bring my phone with me. I just assumed it was related as it happened right after pairing was done.
So to recap: player locks up about 10 seconds after getting power, no matter which input it's on. Switching inputs fices the problem. While it hangs sound is muted, I can press touch screen buttons but nothing happens.
where did you get it from? any kind of warranty?
Possibly why it was removed and then sold. I very much doubt the seller will help...honestly. Might be worth re-installing or updating the firmware.
Edited by DonjSZ5
Bought second hand so no warranty. Maybe I should try a complete reset/factory defaults and see if that helps
