AC Fault
I've noticed that for a while now my AirCon seems to be intermittent. Some times it works lovely, others, it doesn't seem to do anything.  I had it recharged, which didn't really fix it either.  I had my car scanned on VCDS recently, and noticed this error:
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AK HW: 3T0 907 044 AK
Component: Climatronic H14 0302
Revision: 00005001
Coding: 0000000000
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_SK12.rod
VCID: 7BFE07E6F29CB0E62B-802E
1 Fault Found:
9480469 - Control Circuit for A/C Compressor
B10A9 15 [009] - Open or Short to Plus
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 111800 km
Date: 2016.04.18
Time: 20:33:14
Could it just be a fuse or dodgy connector to the AC compressor?  The climate control unit is working as far as I can tell - when I press the AC button, the LED lights up and the displays shows the AC notification.
It seems like a weird conicidence that this error has appeared after doing my IM replacement, so I have a horrible feeling I've disconnected the AC connector and forgotten to reattach it.  I'll check the fuse and that this wire is not disconnected.
What else should I look at?
Edited by planehazza
Sorted, I just hadn't plugged it back in, ha!
