Adjust clock
How do you adjust the clock on a new Octavia 2?
I have sat nav and maxi dot and all the manual refers to is a know to turn?????
Any ideas as it is wrong and annoying me!
It's in the settings.
press and hold the toggle switch on the wiper stalk to acess it. use the reset button to select your choice.
Sorry, replying to this a bit late, been on holiday.
Don't you turn the trip reset **** (the one at the bottom left of the maxidot display) -- turn it one way and it changes the minutes, turn it the other way and it changes the hours? Push it and the trip counter resets to zero.
At least, that's how it is in my Octy 2 Elegance with Maxi Dot (bit not factory satnav).
that's right scroll to settings and the select the clock. You set it from there using the 3 stalk buttons.
This menu also allows you to bring your radio preset/track/volume settings up on the maxidot instead of the tip computer and allows you to alter the 'light assist' settings etc (if fitted).
The button below maxidot only resets the permanently displayed trip meter and it doesn't turn as far as i'm aware.
