How do you remove rear ext door handle
Hi guys, I'm really needing some help here. The nsr ext door handle has stopped working, phoned the skoda parts in Inverness, the parts guy knows what part I need " it's a common fault" he said. Had to use a break in kit to get the door open due to the kiddy lock being on. It's scary how easy that part was. What I do need to know is, how do you remove the ext door handle. I just can't figure that part out.
I worked out how to remove the rear door handle. On the door edge you will find very small grommet, remove this, then you will see a T20 torx head set screw. Turn this lefty loosen till it stops, the end cap next to handle will be loose, remove this. To remove the handle part, hold it against the car, pull to rear of car. You will feel it move then pull it out and keep going and the forward section will then come out.
