Shiny black exterior trm scratch removal
The shiny black window trim on my Octavia VRS has millions of small scratches. Is they any way to hide or polish it out?
There is indeed!
Do you have a DA or rotary or will you be working by hand?
Need a light polish or something with fillers to mask it.
Megs 205, Autoglym SRP, AF Tripple or Ultra Glaze and 50. Cal Cover Up would all work.
Sent from my SM-N910F using Tapatalk
Cheers, I can borrow a rotary buffer.
Have you used one before?
I'd recommend using a filler polish or glaze if you haven't.
There is indeed!
Or Poorboys Black Hole.
Be careful with rotary, run it at low speed so you don't heat up the plastic.
