Adding POI's to Amundsen?
Help! I must be doing something wrong but I can't work out what and I don't want to screw anything up.
Using the 'My Destinations' portal on the Skoda Infotainment site, I have created POI's for National Trust and English Heritage and loaded to an SD card. The resultant PersonalPOI file structure and content looks the same as on the Skoda Maps card but the Amundsen (MIB model) doesn't show it when I use Nav>Version>Update.
1. So far I've had the Maps card in one slot and the new POI card in the second slot - should I remove the Maps card and just have the new POI card in one slot?
2. Since the Maps card already has POI's, will the new POI's add the additional categories or overwrite the original factory installed ones (yes I have backed up the Maps card just in case)?
Any useful advice gratefully received.
Do not overwrite the original POI. You can add your own. The menu controls to be showed.
Sorted. I had to use the Amundsen menu to dismount my media card before I removed it and replaced it with the POI card.
