passenger window problem
have a 2009 LE Octavia
i havent opened all the windows in ages . monday its red hot so opened all 4 windows via key fob to let heat out . drive off and a couple of mins later close all windows via drivers door arm. all go up except front passenger window which goes up closes and then comes back down to half way . tried loads of times but same result . tried same at home with switch in passenger door arm and it works perfectly tested plenty fine each time. no real squeal from window rubber and cant really see anything in the door rubber.
any ideas
Could just need re programming. Hopefully someone will be along to tell us how to that I my passenger one goes to the top then tries to keep going
