VRS CR tech info required.
Replacing thermostat on wife's 59 plate VRS diesel (CR engine).......is it a swine of a job?!
Cheers.
  • 4 weeks later...
From start to finnish it took me about 4 hours, hey ho.
Should've done, apologies.
Basically the throttle and EGR housings need to come out the way......and the supporting bracket that's bolted to the block. Dipstick tube off to.
I had the car jacked up and the undertray off but I think this wasn't really required and the job can be done with all 4 wheels on the ground.
I temporarily refitted the dipstick tube when I removed the 'stat housing or else I would've got coolant in the sump.
That's about it really, reassembly is a reversal of removal as Haynes would say!!
