Maximum startup volume not holding configuration?
Ni, noticed lately that my Amundsen+ is not using the setup of maximum startup volume. I set it to "8" but it always start at "5" if the ignition been off for more than a a minute or so. Any ideas? Not the biggest problem in the world but somewhat annoying ...
Drive safe,
Anders
Edited by AndersNordh
Hi again, one thing that came to my mind, could this have anything to do with replacing the battery in the key fob? I actually ything this issue came up at that time whe the battery was replaced ...
Have a nice evening!
Hi again guys, it had to do with replacing the battery in the key fob. All other personal settings were used in the per key fob setup but NOT the maximum startup volume. Treble, base ... everything ... but after a re-sync of the key it worked again as supposed, very strange so after a battery change, perform a sync as well even if everything seem to work.
Kindly,
Anders
