front windows acting strange
on my 2012 skoda octavia it has electric front windows and manual rears
just recently i have had issues with the front electric window when sometimes they work or work hesitantly
took a reading with my vcds and through up the following codes.
as this happens to both windows is this likely to be the main window switch on the drivers door that controls the left and right windows
00912 - Window Regulator Switch; Front Left (E40): Implausible Signal  Possible Causes
  • Wiring/Connector(s) to Window Regulator Switch; Front Left (E40) faulty
  • Window Regulator Switch; Front Left (E40) stuck
  • Window Regulator Switch; Front Left (E40) faulty
Possible Solutions
  • Check Wiring/Connector(s) to Window Regulator Switch; Front Left (E40)
  • Check Window Regulator Switch; Front Left (E40)
    • Check Meas. Value Blocks (MVB) for Plausibility
  00913 - Window Regulator Switch; Front Right Driver (E81) : Implausible Signal  Possible Causes
  • Wiring/Connector(s) to Window Regulator Switch; Front Right Driver (E81) faulty
  • Window Regulator Switch; Front Right Driver (E81) stuck
  • Window Regulator Switch; Front Right Driver (E81) faulty
Possible Solutions
  • Check Wiring/Connector(s) to Window Regulator Switch; Front Right Driver (E81)
  • Check Window Regulator Switch; Front Right Driver (E81)
