Side mirror glass and cover removal
Wondering if the mirror glass just unclips by force, or is there a clip behind that needs to be released first?
Mirror cover removal should then be obvious.
Spiro
The mirror glass is removed inserting a wide plastic wedge from the top and using it as a lever to push the glass out. You can swivel the mirror all the way down beforehand to assist this.
After removing the glass, the housing can slide out by pushing and unclipping three clips which are behind it.
There are more clips under the housing to remove the frame.
