Will Current Tyres fit these Alloys?
They should fit without any trouble. The Pegasus wheels are 7" wide and the Turini are 7.5" which will make little difference.
I'd go as far as to recommend the change because it will tighten up the handling a bit without affecting the ride noticeably.
The Pegasus are 8” wide and ET44, meaning the outside edge of the7.5” ET52 Turini’s will sit 14.4mm further into the arch (and possibly look a bit silly without spacers to bring them back out, without spacers, this is not going to help the handling one bit (the chances are you will not notice any difference though)
Post #3, which I now can't edit 100 minutes later!! was made on the basis of post #2 having the correct wheel widths and both having the same offset. If post #4 is correct, I'd agree with it.
Whoops my mistake - I posted the rim width for the 17" Octavia Pegasus wheels. The 0.5" difference in the other direction shouldn't make a difference either.
Thanks lads, appreciate the replies.
