cam belt
i think my water pump has gone so i will have my cam belt done at the same time how much to have the cam belt done?
the bits from skoda are about £230+labour or can be had cheaper if you find a decent parts place.
i have just bought the stuff to do mine and it cost £129 but thats mates rates :D
i got a firtline water pump as these are supposed to be better than the originals, the original pump has a plastic impellor where as the firstline unit is all metal :)
cambelt alone maybe des but not for cambelt, tensioner, pulleys and water pump.
unless my local dealer was ripping me off
Try G.S.F (ON LINE)
WWW.GSFCARPARTS.COM
THERE GOOD AND MUCH CHEAPER THAN A SEALER 4 THE SAME STUFF
The ETKA prices I have from a while back are:
Toothed belt - £23.50
Belt tensioning damper - £74.61
Tensioning roller - £44.89 (but not sure if this gets changed as well)
Water pump - £55.46
= almost £200
And those prices should all be plus VAT.
so i wasn't getting ripped off then :)
Just Been To My Local Garage And They Said They Can Do The Lot For £290 For Cash
Who can change mine for me for cash????
And fit me some new dampers and some Eibach Springs????
cambelt alone maybe des but not for cambelt' date=' tensioner, pulleys and water pump.
unless my local dealer was ripping me off[/quote']
In a cambelt kit you get a cambelt, a tensioner and a ickle wheel (
How much have you got to spend. :D
why?
why?
Err!!
Does the tensioner and water pump need doing at the same time on the TDI engines also? I ask this as am well on my way to 60k miles which i believe is when you need to change the cam belt on the Tdi.
Mine is a 2003 model 110Tdi
about
