Bolero - low spec
Hi. Recently bought a second hand Octavia estate - mark II which has a Bolero 6cd changer head unit with SD card slot. Annoyingly it doesn't have the telephony or auxiliary input connection.
Is this something that is relatively easily retrofitted or am i best off replacing with a new head unit.
Brian.
You can add in a Bluetooth module, fits under the seat. It will also need coding to the car. Or you can replace the headunit. Just beware, if you stick with original equipment (top spec Columbus with nav etc) you will still need the Bluetooth module too.
