mk2 pre fl cruise control problem
Did measuring blocks on Wednesday on the cruise control stalk and they where showing all buttons and pedals were doing what they should do but scanned and tried today and the buttons on the end of the stalk where not showing as working. Is there any way to test the pcd board in the stalk before buying another stalk?
Friday,17,March,2017,15:04:41:23200
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: TMBBE21Z372064440 License Plate:
Mileage: 201390km-125137mi Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 36 42 44 46 52 56 62 72 76
VIN: TMBBE21Z372064440 Mileage: 201390km-125137miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LD HW: 03G 906 021 LD
Component: R4 2,0L EDC G000SG 8514
Revision: --H05--- Serial number: SKZ7Z0F3834966
Coding: 0000072
Shop #: WSC 73430 790 00000
VCID: 6CD0158B4FD1572125-8039
1 Fault Found:
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 201239 km
Time Indication: 0
Date: 2000.00.00
Time: 04:14:10
Freeze Frame:
RPM: 1134 /min
Speed: 17.0 km/h
Load: 8.2 %
Voltage: 14.36 V
Bin. Bits: 11101000
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8A92C76E271CB9D0-806B
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 J
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3D76E8CF642B0EA9C2-8069
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004493410
Coding: E18A8F031004140000110D000000000000297F075C
Shop #: WSC 17009 576 03133
VCID: 2B52D6978A5F90196C-807F
Subsystem 1 - Part No: 1Z2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SK351 012 0401
Coding: 00063477
Shop #: WSC 17009
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 031006 014 1201
Coding: 00471077
Shop #: WSC 17009
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0T2YYJ
Coding: 0020788
Subsystem 1 - Serial number: 6332MSME122536640
Subsystem 2 - Serial number: 6342MSME124568165
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0002042
VCID: 010E543F5853AA49E6-8055
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00895 - Cruise Control Switch (E45)
014 - Defective
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0F3834966
Coding: 0007401
Shop #: WSC 14557 604 69422
VCID: 397EFCDF70033289EE-806D
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001069051440
Coding: 3D7F074007001303
Shop #: WSC 73430 790 12345
VCID: 2C50D58B8F51972165-8079
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1612
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
VCID: 2D56D88FB44B9E2972-8079
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.clb
Part No SW: 1T0 959 701 E HW: 1T0 959 701 E
Component: Tuer-SG 005 0946
Coding: 0001014
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3566F0EF5C1BD6E90A-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 01801A085283007F3F02050FC008DF96907C00
VCID: 03025E37424FB859F4-8057
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.clb
Part No SW: 1T0 959 702 E HW: 1T0 959 702 E
Component: Tuer-SG 005 0936
Coding: 0001014
VCID: 3A7CE3D375053991E7-806F
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 377AFAE7461724F918-8063
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
VCID: 3878F9DB4B092B8111-806D
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
End-------------------------(Elapsed Time: 02:09)-----------
Unclip the PCD board, spray some electrical cleaner on it and reconnect. Mine stopped working before, did this and all is good again.
