Skoda octavia mk2 2.0 tfsi battery draining
Hi
Hope you guys can help
1 night after 10 hours of being parked up the battery died. Called AA who used a booster pack to start it could not see any reason for the battery to die. Did say it was on the low side but in the morning if its dead probs will need a new battery
In the morning battery was dead so jump leads got it going and i put a new battery in...parked up for 2 hours on a new battery and its dead
I cant see any lights on or anything thats visible that would drain a battery so quick
Any ideas would help
Noticed any fan working after parking?
Have you replaced the infotainment system? It has been reported that some could drain battery due to bad can bus cooperation or kind of adjustments could resolve issues..
Yes when i put on jump leads in the morning the radiotor fan turned on for like 10 seconds until i got to the ignition and started
  • 2 months later...
Turned out to be the engine bay fusebox shorting..somehow got water init..you have two options either strip old one comes out into like 3 pieces and dry or just get another fusebox. Thought il post incase anyone else ever had a similar issue
Yes this has been kinda a common issue on many...
