Which Dump Valve
Hi
I am going to fit a ABD cold induction kit very soon and I would like some advise on which type of dump valve I can fit
I would like to fit a very loud dump valve but have read a recirc type DV must be fitted - are these quiet? can you fit an atmospheric type DV without a warning light comming up on the dash
mick
Try using Search to research this since it has been covered in depth a number of times. The car comes with a recirculating DV as standard since that is what the engine needs to run properly. Quite a few members have replaced that standard cheap and cheerful DV with a metal one made by Bailey or Forge. IIRC there is at least one specially designed atmospheric DV available which will give you the sound you want without upsetting engine fuelling - but at a considerable price.
