Air conditioning not working along with other fault codes
Hi,
The aircon has not been working in our Octavia 2.0 TDi for a while now.  When I scan for fault codes I am getting the following:
00988 -044 Lamp for Brake Light: Right (M10)
sporadic
012-Electrical Fault
00834 -041 Signal for Activation of Heated Rear Window
sporadic
0009-Open or
02071 -036 Local Databus
sporadic
004-No Signal/Communication
01320 -036 Control Module for Climatronic (J255)
sporadic
00059 -044 Terminal 30 for Interior Lighting
sporadic
01520 -040 Rain and Light Recognition Sensor (G397)
sporadic
00926 -043 Terminal 30
sporadic
011-Open Circuit
Everything else appears to be working ok, LCDs & LEDs working on the control, fans operating, flap motors operating, just no cold air.  Have had system re-gassed twice and checked for leaks with none found.
Any thoughts?  I'm wondering if it could be as simple as a dodgy earth somewhere, or maybe something more sinister...  Otherwise, I'll get in touch with my friendly local member and get a full scan done to see if that helps identify the root cause.
Cheers, Alan
As having seen there is intermittent fault in the climatronic module, may I suggest fault could be located there?
If unit produces intermittent faults maybe the module does not give command for the compressor to start working so producing cold air (AC) in sequence..
It may worth starting searching the issue from this even if possible replace it but not sure yet...also it is costy.
Any one other in here could pass any idea..
