Saving seat position to Key with Personalisation
Hi
My Kodiaq has the personalisation option. I have succesfully assigned the keys to diferent accounts.
Unfortunatly I can not figure out how to assign different seat positions to each key. So that the seats change to the appropriate position when the different keys are used to unlock the car.
Anybody with a simular setup figured it out?
I'm not too sure if it's the same as my S3 L&K but that also has an option to pick a driver when you get in the car - even when just one key is used.
On 5/18/2018 at 17:34, MooseUK said:
Hi
Yes, you need do NOTHING apart from change the seat position to your preferred settings and press '1' or '2' depending on which preset is yours, then press and hold 'SET' until you hear the audible 'BEEP' and its all done for you.
ANY changes you make to the seat, climate control, wing mirrors and radio presets will ALL be stored under the appropriate profile depending on which key was used to unlock and gain entry to the vehicle.
I hope this helps.
