cam belt replacement interval
Hi
What is the official milage that the cambelt needs to be changed
Yeti adventure 4x4 TDi
Its due for its MOT and I know the front disks are worn and the pads probably need changing.
getting a bit of shudder when braking at hi speed.
It still a very stable car , I've been using it on the German autobahns , you know that place where  you can be
driving along at a sedate 100mph and something goes past you as a blur.
If anyone is interested average fuel consumption if revs kept below 2500 is 780kms /tank
but if the engine revs are btween 2500 and 3000 it drops to 700kms/tank
I think earlier models were 4 years and later models (with a more robust belt) are 5 years.
Also earlier models if already fitted with the later belt are 5 years.
Isn’t it advisable to also get the water pump done at the same time ?
thanks for the replies
