Oil problems
Hi guys I have a 1.9tdi octavia I seem to be getting oil from my breather pipe going into the my boost pipes is this normal or not thanks for any info
A little bit of oil in the pipes is normal due to egr recirculating the fumes back into the inlet side but if you are experiencing excessive oil consumption then you may want to check out the source.
