MK2 fabia 1.2 htp 2008 coil wiring harness
Hello fellow Skoda owners does anyone have any clue on the fabia 1.2 htp 2008 engine Ignition coil wire harnesses 1. 2. 3. 4. What contains
POSITIVE AND NEGATIVE
thanks
3 cyl or 4 cyl engine ?
If its a 3 cyl then it differs from each cylinder....depending on engine.....
PS found it...To me (you need to confirm) this is coil pack 1 Plug ??? if so.....then
PIN 1--- Black---- Positive connection 87a ignition live
PIN 2 ---Brown / black trace --- Earth
PIN 3 --- Green  ---- Engine ECU connection
PIN 4 --- Brown --- Earth
Edited by UrbanPanzer
  • Sponsor
Black will be +12V with ignition on, I think; brown and brown/black are earths; green is from engine ECU to control coil.
Mines a 3 cyl that coil was coil 3
