bmn inlet manifold required
Hi Anybody else had an issue with coil light coming on due to leaky inlet manifold seal? I need to buy a bmn manifold but cant find a good one... any help or advice? Ebay ones all have the leaky oil marks.
Aren't you better off fitting an alloy BKD manifold anyway, do away with the crappy flaps.
Maybe, I heard that they make them from plastic so if they break they do not smash everything else up?
BKD?  I did not know that would fit anybody know the options?
yes, that is what has happened, oil squirting out.
so what would you recommend?
Fit a BKD manifold
I did not know this was an option.
whats the point of the flaps?
Now you do
I have ordered the ~BKN and will let you know how I get on, Thank you for your help!!!!
BKD?
cool, post some pics up :)
Yes BKD
  • 5 weeks later...
Did you get this sorted?
Not yet, I have been on holiday and the mechanic I wanted to do this has been flat out.
Ok, no problem, if your handy with the spanner, you could do it yourself?
I have a short attention span and zero tools...
Ah, that don't help :D
