passenger window auto-close blues
I have long had an intermittant issue where the front passenger-side window would not close automatically (and be hard to close holding down the command switch); instead if would act as if it encountered an obstacle about 1/3 up and another about 2/3 up. At times it might not have been wrong as I have side deflectors installed and the one on the right wasn't fixed properly, but that's been corrected. Today I apparently spent about an hour trying to restore proper function, without full success. Closing the window with a single touch still doesn't work (nor does closing it via the keyfob :-/), but at least I can close it with a prolonged press. It will still stop at one or both of the apparent problem locations but at least it won't go down again (and will continue to go up when I renew the button press).
Is this a common/known issue, and does anyone have suggestions what I can do about it? In particular, can one deactivate the "let's scroll the window back down" feature?
FWIW, my passenger (wife) is not used to fully automatic windows, and has a habit of starting to close her window just before I use the commands on my side to close all windows. Can that simultaneous activity throw the computer off-track?
Have a read of this current thread:-
Like yours, the stiffness is at 1/3rd and 2/3rd position.
Apologies, I was too knackered to search for similar issues when I posted this ...
Someone can close this thread, the other one is indeed about the same issue.
Edited by RJVB
