MFC displaying wrong door open
My Octavia VRS MK2 is displaying wrong door open on the MFC dash.  The front two doors' open display graphic are swapped.  Anyone seen this problem before?
Have you made any changes?
Changing the coding in the gateway would cause this
or retrofitting a Facelift cluster in a pre-Facelift with an older gateway
Check in VCDS whether its set to LHD or RHD.
