ignition live fuses on Rapid 2016 plate
Hi,
Looking for an ignition live fuse on the fuse board for a piggy back fuse holder for a dash cam.  Are all fuses permanently live? (Cigarette fuse is)  any suggestions on which is the best ignition live fuse to use?  Tried 22 but does not work.
I take it that pushing key into ignition makes the fuses go ignition live?
Many thanks
ps, first experience of Skoda....
Easiest is #34 - heated windscreen washer jets. It's ignition switched, and generally empty in the UK. Be aware that you may need to rotate the fuseholder by 180' if it doesn't work to start with.
