VCDS
Morning all, this is a quick question... does anyone have a VCDS and able to turn the sound actuator down to 0%? It’s horrid to hear.
I’m based Ashford Kent, once allowed to travel I’d pay for your service/time.
TIA
Mark
BTW 63 plate octavia vrs
Here is the Map of Owners of vcds. Try contacting a member near you via private message as a first.
Regards.
I have VCDS but I'm in Brighton which i quite a way for you to travel!
Regards.
Brilliant thank you!
  • 2 months later...
Hi, don't know if you are sorted but I have VCDS and live in Cranbrook not too far away?
I assume you're using the car in sport (or is it VRS) mode then.
I've got all the sport setting apart from the engine sound in the individual mode
Hey, sorry I should have updated. I found someone in Hawkinge not far from me and it was sorted. Thanks for the reply though.
Mine is pre vrs button, so mode only. Using the sport mode gave the horrid fake noise. In individual mode I selected all to be sport and engine as normal. I’ve had the sound actuator turned completely off now and I get the “sportier” response of the accelerator and none of the faked noise.
